Zoom MRS1044 £120
gubblegubble Frets: 1826
edited October 2014 in Misc £
For sale zoom digital recording studio with the following specs
Hardware
44.1 kHz sampling, 16 bit linear format with no compression
44 hours recording time with internal 15 GB Hard disk, up to 999 songs
24 bit signal Processing and 24 bit A/D, D/A conversion
10 audio tracks, Stereo Drum track and Bass track, total 13 tracks played simultaneously
2 Phantom powered balanced XLR inputs and un-balanced 1/4" jacks, 2 tracks recorded simultaneously
S/P DIF Optical Digital output
MIDI In/Out, Expression pedal in and Foot switch in
Optional SCSI and USB add-in card slot
Back-lit LCD display with contrast trim
Hard disk recorder
10 Virtual takes for each track
EQ for each track
100 Markers per a song
100 Sequence and Manual scenes per a song
Easy bounce mode
Auto Punch In/Out, Manual Punch In/Out
A-B Repeat function
Scrub/Preview function
Drum Machine
Real Drum & Bass sounds came from Zoom RhythmTrak series
8 touch sensitive pads, x 3 banks make 24 sounds per a drum kit
250 user programmable patterns per a song, selectable from 400 preset patterns
Over 10,000 notes recorded per a song
20 Drum Kits and 10 Bass Sounds
Pattern recording by MIDI note triggering
Multi Effects
Modeling guitar effects, VAMS (Variable Architecture Modeling System)
Mastering effects, Insert effects and Send/Return effects available
4 Algorithms - Guitar/Bass, Mic, Line and Mastering
4 Modules - Compression, Pre/Drive Equalizer and Modulation/Delay
6 Insert effect types simultaneously
2 Send/Return effects simultaneously from Chorus/Delay/Reverb
Dimensions
16.75 (w) 10.25 (d) 3.125 (h)
Comes with power supply and flight case
Whoops realised i put the wrong price in so just edited :)
Price includes delivery or feel fre to collect from southampton / new forest
