That said, in my experience they do usually still sound better for acoustics. Don’t worry about phantom power, any properly designed DI box will either use it or ignore it.
Phantom power is most dangerous when plugging in things like iPads and phones via the headphone ports. The phantom power can reverse bias the output coupling caps on the headphone output which shorts them and then the DC can destroy the headphone amp in the device.
So never use a device like this direct to a mixer, always use a DI box inline. With todays iPad control surfaceless mixers it's very easy to accidentally turn it on.
if you're going straight into a PA system or mixer from an active pickup, using a normal length (20 ft or so) shielded cable with standard jack plugs you don't need the DI box.
If it's a bigger venue and you have to run a cable to the back of the hall, say to a sound man, then use a DI box. It allows longer cable runs with minimal signal degredation.
My band and a lot of other bands use digital stage boxes these days too. So everyone plugs in the stage box but there's only single cable cat 5 cable going to the mixer.
In this scenario you can view the desk as being on the stage and a Di is less important although it's still good practice to use a DI box
Re phantom power I'm more concerned around someone else in the band plugging in/taking out a mic/input from the desk when the phantom power is on or forgetting to turn it off etc.
Hope it works out for you.
