NAD SV20H
DdiggerDdigger Frets: 2465
edited September 2023 in Amps
Gumtree bargain £350.
Seller was a couple of hours drive from me, but agreed to hold on to it until I could travel down the following evening.  Had a go of it in the garage and he offered to give me some tips on setting it up and I took him up on that a learned a few things.
I have Power Brake and a Jettenuator, so will see which one works best with it.
The cab is a model 1966b, with 2 x 12s (G12T-75s) - that was another Gumtree bargain.
  • Wow, super cheap, great amp too
    ‘It is no measure of good health to be well adjusted to a profoundly sick society’
  • mo6020mo6020 Frets: 459
    Great price for a great amp. Congrats.
    "Filthy appalachian goblin."
    https://edmorgan.info
  • £350???
    Bargain of the year!
  • DdiggerDdigger Frets: 2465
    Fella in Cumbernauld was selling two of these and two SC20Hs and some other stuff.
    I just happened to search on Gumtree when the ads had only been up a hour.
    Missus was bending my ear about the diesel cost, but I showed her the RRP cost.
  • Dave8Dave8 Frets: 276
    Absolute bargain!  Enjoy the amp
  • yockyyocky Frets: 816
    Nice catch. Not sure about those settings though......
    I'd be surprised if the Powerbrake didn't win that battle vs the Jettenuator hands down.
  • soma1975soma1975 Frets: 7029
    Welcome to the club. I'm on my 4th (a combo version after thinking the grass might be greener elsewhere)
    I ran one with a power brake for ages and it is wonderful with that amp. Only thing better I have used so far is is the toneking iron man 2 mini
  • Alex2678Alex2678 Frets: 1177
    Shit the front door that’s a bargain
  • With a Marshall I’ve always found the Powerbrake the best, as long as you don’t attenuate to the extreme.
       I also recently moved on an Ultimate attenuator made in the US, and for the money it was brilliant. It was a reamper, so you could attenuate right down to bedroom level and still reproduce a great sound. Also had twin master volumes for solo boost.
  • JMS96JMS96 Frets: 142
    Awesome - I have exactly the same, except the 1966A. I also have the matching 1x12, but it's just not as good as the 1966
  • ICBMICBM Frets: 73237
    What a bargain!
    The G12T-75s aren't going to be the best for it, so you can now justify spending a bit more on some - I would recommend Greenback G12M-25s, Heritage G12H-30s, or one of each (G12M at the top).
    Or possibly the Marshall Vintage/Heritage pair... which coincidentally I have and might sell...
  • YorkieYorkie Frets: 1566
    I think this beats my DSL40c @ £200 score from earlier this year :open_mouth:
    Adopted northerner with Asperger syndrome. I sometimes struggle with empathy and sarcasm – please bear with me.
    My trading feedback: https://www.thefretboard.co.uk/discussion/210335/yorkie
    ICBM said:
    What a bargain!
    I have some spare speakers (which I have been collecting when they come up cheap), but not had time to try anything out yet.
    Two G12M 25w 16ohm
    Two G12H 30w 8ohm
    One V-Type 70w 8ohm
    One WGS ET65 65w 8ohm
    One Harma Classic Rube 50H 50w 16ohm
    Two G12M 25w 16ohm
    Two G12H 30w 8ohm
    One V-Type 70w 8ohm
    I would definitely try the two G12M-25s first, as that's the simplest option and quite likely the best.
  • I've owned an SV20H before, for a few years it was my main amp.
     Experimented a lot with different speakers in my 2061cx 2x12 cab, including a pair of G12M20s (which are essentially the same as yours).
    The SV20 will compress, almost to an unpleasant degree, above 6 or 7 volume. Add an overdrive pedal and it can get very squishy. I settled on the G12H30's because it flattened the mid-range, allowing for much more nuance at higher volumes. At low volumes it won't matter so much.
    The G12H30's have a bigger low end, which the amps EQ can handle well, rolling back the bass a little.
    I agree with all that - especially about it becoming badly overcompressed with pedals at high volume. I would suggest the H30s too, but for Ddigger it will mean rewiring the cab - not a huge job admittedly.
