TRADED Ibanez AZS2209H Prestige Tri Fade Burst £1200 posted
Moving this on as I’ve had something else come in that I’m gelling with more.
This is an excellent guitar and so well made. It’s in fantastic condition. Setup with 10-46 gauge and a nice comfortable action, around 1.6mm at the 12th fret across all strings.
These Ibanez AZ’s have the Dyna switch which gives you a few more options over a standard 3 way switch.
Full spec below.
- Neck Type: AZ Oval C S-TECH WOOD Roasted Maple neck
- Body: Ash body
- Fretboard: S-TECH WOOD Roasted Maple fretboard w/Black dot inlay
- Fret: Jumbo Stainless Steel frets w/Prestige fret edge treatment
- Number of frets: 22 frets
- Tuning Machine: Gotoh ® Magnum Lock machine heads w/H.A.P.
- Nut: Bone nut
- Bridge: Gotoh® F1803 bridge
- Neck Pickup: Seymour Duncan® Magic Touch-mini™ (H) neck pickup
- Bridge Pickup: Seymour Duncan® Alnico II Pro™ Custom (S) bridge pickup
- Hardware Color: Chrome hardware
- Case/Bag: Hardshell case included
Neck Dimensions:
- Width at Nut: 42mm
- Width at Last Fret: 56.4mm
- Thickness at 1st: 20.5mm
- Thickness at 12th: 22.5mm
- Radius: 305mmR
Comes the hardcase inc tags and Ibanez multi-tool.
£1200 posted.
More pics will be added later on today.
![](https://i.imgur.com/csoU86x.jpg)
