Paper or poly cone speaker?
beed84beed84 Frets: 2450
So I'm looking at getting either one of these for my SF Champ:
https://jupiter-speakers.com/collections/alnico/products/8sa-8-15w-vintage-american-small-alnico-guitar-speaker
https://jupiter-speakers.com/collections/alnico/products/copy-of-8sa-8-25w-vintage-american-small-alnico-guitar-speaker
The paper cone is what I'm leaning towards as it's rated at 15w, which is roughly twice the power of the amp. Correct me if I'm wrong but I think that's the general rule of thumb when matching a speaker to an amp.
I'll be mostly playing clean and won't be driving the amp too hard, but there will be occasions when I'll want to use drive pedals too.
My question is: because of the delicate nature of the material used for the paper cone version, will using a OD or gain pedal be too much therefore causing damage to its elements?
Any help before I pull the trigger will be much appreciated.
(Side question: I'm guessing 8ohm speakers are a no go? I ask because a bunch of second hand 8 inch Eminence speakers have come up on eBay and are a bit more affordable, albeit not alnico.)
    If you're within the power rating you'll likely be fine paper or otherwise. Paper cones sound a bit different when they distort, some really like that sound, some dislike it. If you have the original speaker it'll likely be a paper cone (I'm not super familiar with SF era though so could be wrong)
    You'll want to replace the speaker with similar ohmage - a stock SF champ should be around 4ohm from memory. If a transformer has been changed it might take something different,
  • They both have a 14oz magnet so the 25watt speaker will just be a bit tighter sounding when driven hard.
    Fwiw, do the midrange/raw mod (lift a bass pot lug and have a different value on a switch iirc). It made my champ way more fun.
  • ICBMICBM Frets: 73096
    edited September 2023
    Paper cone is the classic for guitar amps. But do you mean the voice coil former?
    Don’t use an 8-ohm speaker with a Champ unless it has an output transformer designed for it - 3.2 ohm or 4 ohm only.
  • beed84beed84 Frets: 2450
    Okay, that's useful to know. I'm now thinking the ordinary coned speaker might be better in the long run – I'd be a bit bummed to have a speaker that sounds great clean but not so great overdriven. Food for thought. The mod sounds interesting too but I don't know if I'd have the guts to tamper with the circuitry. Maybe if I had another Champ spare I'd try it!
    I think so. All I know from my YouTube research is that paper coil was used in the early days until they realised it started to burn when driven too hard. I'm hardly the most aggressive player in the world but I'd be worried to put an overdrive pedal into it and it suddenly started to smoke!
    I'll take the advice on the ohmage question. I think I was trying to force an idea that in reality I know won't work.
    Thanks for everyones input, it's really helped in making my decision
  • Dave_McDave_Mc Frets: 2404
    That's what I was thinking. I could be wrong about this, but I think the Jupiters are rated for a lower wattage when they have a paper voice coil former- in other words they've taken that into account when rating them, so as long as they're high enough for your amp, you'd hopefully be ok. Or you could contact them to check it'd be safe with your champ.
    There's a good (sponsored) vid on Youtube (you've probably already come across it) where Jack Fossett compares a couple of Jupiters with the different voice coils.
    Yes, exactly.
    A 15W speaker is fine in a Champ.
    ICBM said:
    Yes, exactly.
    Although I understand it will work in the Champ and why they've rated it lower than the 25w version, I suppose I'm concerned I will potentially cause it damage if I slam it with an overdrive/gain pedal. Or am I being a complete noob?
    Good idea. I've contacted Jupiter to see what they say and whether or not the 15w will meet my needs overall. I did see the Jack Fossett video. I'll watch it again though as I've probably missed something.
    Champs are only 6W. Even fully overdriven into a square wave it can’t put out more than 12W. OK, there are sometimes other factors in speaker damage, but I would be happy putting any 15W speaker into one.
    This is also helpful to know, and I'm grateful for your experience. Although I'm still undecided what to go for, it's reassuring to know I can choose the 15W version without fear of it going kaput under normal use. Once I've received my chosen speaker and have fitted it, I'll update the thread in a couple of weeks to let you know my verdict.
    ICBM said:
    Yes, exactly.
    That's what I'd have thought, but I didn't want to say for sure just in case it wasn't! I've had the little 15W
     Jensen Mod 6" in my Fame Tube 5 (more or less a champ) and it was fine. (Currently got slightly higher wattage speakers in my low wattage amps but that's for tone rather than power-handling.)
    The paper ones seem to be a bit brighter, at least judging by the video- I've never tried the exact same model head-to-head (you can only really do that with Jupiter I think? Most other companies don't seem to let you specify the voice coil former), but the couple of paper voice coil speakers I have do seem pretty bright up top (granted, a ton of things affect the tone).
    Will be interested to hear what Jupiter says and what you think of the speaker when you decide what to go for. :)
    UPDATE
    So I enquired with Jupiter if there was a more affordable shipping option – the cheapest was $75. They said HiFi Collective in the UK would be stocking the speakers in the new year, otherwise they could knock $25 off the shipping fee and would send an invoice if I wanted to go ahead now. I agreed, said thank you, and asked which speaker they think would be better for my needs before going ahead – the paper cone or standard. That was a few months ago and I haven't had a response since.
    Meanwhile, an Eminence Patriot 820H came up on eBay a couple of weeks ago, which I had in my last Champ. I won the bidding just shy of £40. However, while it sounds great, I'm keen to try the Jupiter alnico. I'll try with HiFi Collective in the new year, and if they don't happen to stock them, then I'll try Jupiter again. But for now my Champ sounds much better than it did  :)
    That's very interesting, thanks very much for the update. I think Hi-Fi Collective are already stocking their capacitors, so that stands to sense that they're going to get their speakers too.
    Nice score on the Eminence :D
  • beed84 said:
    UPDATE
    Most people seem to get their Jupiter's from tube-town in Germany, their shipping rates and prices are fairly reasonable. I've not bought from them myself however.
    Thanks. I was quite pleased when I won the bid! And yeah, I think I'll drop them an email to see if they can confirm whether they're getting them in or not.
    Well, I checked their site and they have the 8SA. I added it to my basket out of curiosity but you have to spend a minimum of €160 to place an order – there's nothing else I need. However, if push comes to shove I could add a couple of 12AX7s as spares for my amp and pedal. We'll see.
