Pickup swap and a very dark Strat
Just collected my Strat from my local tech after he has fitted a brand new Fender loaded pickguard - vintage noiseless pickups - and it is as dark as a very very dark thing, well balanced but dark.   The bottom E and A strings are overwhelmingly loud and sustain forever - as much as any of my LPs - and the top E and B strings - while adequately loud by any measure - sit a long way back in sound terms.
He fitted a new 250k S1 switch so I have the extra pickup options at the same time, while using the original superswitch.
While I'm not a fan of very bright Strats, this is now a bit far in the other direction and I wonder if anyone might have any thoughts.
  • Fender Noiseless pickups never sound the same as vintage-correct single coils. They tend to lack high frequency "chime" and some low frequency content.
  • rlwrlw Frets: 4904
    I've had them before in Strat and they weren't this subdued, but I know what you mean.  Low frequency content is there 150%....
  • soma1975soma1975 Frets: 7250
    I had the same thing with noiseless pickups.
    Good with gain for a smooth tone but no real cut.
  • I'd change out the pots for 500k
    I was wondering about that.
  • Everytime I have tried anything with Fender's noiseless pickups, I have been thoroughly disappointed. They just don't sound anything like a strat.
    Dimarzio are leagues ahead with the Area pickups. I did actually like the Paul Gilbert Injectors much more than I thought I would. Never tried Kinman, but Dimarzio's design is very "similar" to Kinman's (what a coincidence, Dimarzio...), so I imagine they are in the same league.
    In the meantime, you could play with pickup heights/slant - but I'd personally consider switching to something else.
    I like the noiseless pickups and, as I say, I have had them before and I know what they sound like, which is why I fitted them.
    It's just that these sound so much darker than others I've tried and I was wondering what, if anything other than them, might be the cause.
  • Winny_PoohWinny_Pooh Frets: 8078
    edited September 2023
    Could be a wiring issue somewhere or wrong value tone pots. I've heard about S1 switches being temperamental, is it essential? Could a different tech check it out while trying new pots?
  • @rlw ; Although I've not tried them, from what I've read, the Vintage noiseless models are the darkest (most mid-pronounced) of the Fender noiseless pickups. Have you tried the Vintage pickups before, or one of their other noiseless models? Could it be that you've had brighter noiseless pickups in the past?
    I too like noiseless single coils and I have them in all my SC guitars except one. I've settled on Kinmans as I do find them quite a step up from Fender's offerings and they do a range of models that are quite different from one another. They do sound like Strat pickups though and fine ones at that.
    I recently switched one of my Strats from Fender gen 4 noiseless to a set of Kinmans while converting it from HSS to SSS. If you don't mind an HSS configuration, you're welcome to borrow my gen 4 Fender noiseless set to see how they compare to your Fender Vintage noiseless pickups.
