I found myself watching a YouTube video on fret levelling about a week ago, and realised that I knew what needed to be done, in what order, and why - from flicking through Dan Erlewine books, reading posts on here, and watching videos. I’ve often thought of investing in the tools and trying it on a couple of cheap Squiers off Gumtree one day. Then I realised that the tools aren’t that expensive… £150 got me a Crimson fret levelling kit and a radiused fret crowning file from Tonetech. I have a few mid-level (MIM Fender, Epiphone) guitars with less than ideal fretwork, so decided to give it a go.
My recently aquired (from ebay) Roadworn Telecaster played well initially but some buzz and rattling had become apparent. I wasn’t convinced about fret rockers but a few minutes with the Crimson fret rocker confirmed that there was a couple of high frets, so off came the neck. There was still a little backbow with the truss rod loosened, but I thought that’s as good as I’m going to get, and some relief will be added once it’s strung up again.
https://i.imgur.com/MICwFrG.jpgI used 320 grit sandpaper on the levelling beam, which seemed quite fine, but ok as I was a bit worried about taking too much off on my first attempt (the Tele had quite tall frets anyway). I stopped when the last of the blue marker pen spots disappeared. The frets looked very flat at this stage. I started crowning with the radiused/grooved fret file but soon felt confident enough to do a bit with the triangular file. They still looked a bit flat but decided to stop in case I took much off. Polished the frets with some wet & dry paper, 3 grades of Crimsom fret rubbers, and finally a polish with Autosol and a Dremel. After taking the tape off, the crowning looked much better - very pleased for a first attempt.
https://i.imgur.com/zIyUgRL.jpg
Ian
Nice work though, congrats!
(formerly customkits)
My skills only extend to fitting nuts and setups and dowelling holes........
Looks real nice.
I have a Chinese guitar which need a little love.
It has a couple of frets around the 12th -17th frets which make the same note.
