Restringing gets easier with practice, but it's still annoying how much they go flat over the first few hours days weeks. As drofluf says, when they stay in tune it's just about time to change them - the wound ones at least.
You can cut the ball end off and tie them if you prefer
I think that clip on tuners (at least good & decent-ish ones ) are a godsend
And the barefoot buttons on my amp switcher /pedals are great
Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
But it is true that you should pull the string as far through the hole as you can before tying it in whichever method you prefer, since that does minimise stretching. The two best methods are either backwards around the roller and pulled across under the string, or the same way around the roller and tied under the string - both work.
It's also important to wind the string onto the roller in the direction which traps the coil tightly together and keeps the string from rubbing on the side of the slot - for the E strings that's inwards towards the centre of the headstock, for the G and D it's outwards, and for the A and B it can be either depending on where the hole is on the roller, but usually outwards.
https://www.taylorguitars.com/support/strings/changing-nylon-strings
It doesn't help with the tuning issues though!
Eqd Speaker Cranker clone
Just when you get used to restringing on a six-hole classical bridge, you could then acquire a six string classical guitar with twelve or 18 bridge holes.
It should be noted that the "Alba" beads mentioned earlier have a three-hole method of tying in themselves. What the 12-hole and 18-hole bridge does is to incorporate this neater and secure method of tying into the bridge itself.
