Every so often I buy a new bit of kit in the hope that I will find what I am looking for. I never quite seem to. I am just rubbish at finding the tones I am looking for. I think that part of it is that I don't have a good ear for sound, another part is that I always seem to head for a high gain amp sound and turn the gain right up. I can't tell what works before I overcook it.
To be honest I don't think I know my arse from my elbow when it comes to a good sound. I stick on an album - Doobie Bros, Steely Dan etc, and the killer solo tone is just not something I would be aiming for. I can't tell what sounds good when I'm tweaking and generally keep sticking more of everything on!
I like your Satriani high gain sounds, singing with lots of sustain, but I also like good blues tones, SRV, Sayce etc. and just generally earthy 70s guitar sounds.
Anyone else struggle or do you find it easy?
on here but I cannot find a way to describe it and have people understand me.
Recording an electro acoustic also taught me that taking stuff out (frequencies) can have just as much effect as adding stuff in. So don’t just turn all the effects up to max, twiddle some knobs to the left too (they turn both ways).
And when you find something that’s close, SAVE IT. Use that as your new baseline. If it’s saved, you can always go back to that if your subsequent knob-twiddling takes you somewhere that you don’t like so much.
Try and describe the problem you are having, here and on the massive Facebook Helix group. I'm sure someone will understand.
There's 40,000 members on the facebook one. Almost guaranteed to have someone with a solution.
But - give all the info. The full signal path. Photos of the block settings, the rest of your system etc
Generally I like quite a few sounds and I can find them inspirational even if they are really outside of my usual approach.
But at the same time I have been playing for 35+ years now so I definitely have my favourites.
I spend a couple of hours yesterday trying to dial in a great Fender Deluxe type tone with my Helix and studio monitors.
I gave up (again) when I realised that although I like those amps being played by other people, I much prefer Marshall flavoured clean tones that actually have some mids.
The problem was not the tone, it was that it wasn't ever going to be right for me, and I would continue to want a Marshall type instead.
I did spend ages coming up with a good Brian May tone though. I downloaded a load from the L6 custom tone site and then sort of mashed them up until I got something I was happy with. I did need to use a humbucker equipped guitar though. Singles that cannot be put into series aren't enough for that.
I'll think of an album tone that I like then research what's unique about it's EQ. Is it a scooped mid, or does it have lot's of low mid range or lots of high midrange. Will then research what gear combination has that particular EQ. From there I'll think how much headroom I need and what level of compression. That helped me.
For me the appeal of a digital rig is an infinite pedal board where I can model all my fav tones and not be limited by the analogue gear that I own.
This may help you understand the slightly more nuanced aspects of guitar sound and give more of an insight into what it is you're actually looking for. Ramping on gain and effects are hardly conducive to being heard or having a dynamic playing experience either.
Playing with less gain will also help with technique because you'll absolutely make sure notes are hit properly to maximise sustain etc.
Have a look at the gear some of your favourite artists use and just copy those rigs for a kick off. Especially if you're in the digital realm.
I built one of JoBos rigs in my Fractal with Dumbles, Marshalls etc and EV loaded cabs and some choice pedals etc.
I broke out all my best JoBo licks and quelle surprise it sounded like JoBos rig...
That said, it didn't sound like JoBo's rig if I played Slash or Zakk licks. Go figure....
I also don't play outloud very often now, and even before reaching this kind of set up I never really played in public very much, so I've not really had that learning experience either too put the tones together. But on the plus side, I don't really need to concern myself with how my home sounds translate to a live environment as my music doesn't really get heard on much outside of my headphones and desktop speakers.
You would think this would mean that my recorded tones on my covers and original recorded songs would be really interesting and unique, not being based on typical conventional setups etc. However sadly my voice isn't one which lends itself to being accompanied by loud fuzzy dual amp setups with octaves doubled up all over the place so my recordings tend to come with fairly bland generic guitar tones.
https://twitter.com/spark240
Reddit r/newmusicreview
He used the same amp as everyone else, a small tube amp, I think it was a Cornell.
He was playing a borrowed 335 that I set up which he commented had a thicker neck and thinner strings that he was used to (it had 11's on it).
No pedals, amp wound up about 1/3rd of the way, with bass turned down, treble and mids up.
He had less gain than anyone else but more sustain.
He spent no more than 1 minute sorting his sound out.
He warmed up for about 20 mins, whilst chatting to me and a few other people, absolutely shredding arpeggios.
He didn't deploy any of that shredding when he went out and played and he just played... music.
He sounded godly.
It was absolutely one of the best musical experiences of my life.
The other players, all really good guitar players and instructors, sounded great until he played a few notes.
It was obvious he was just on another level.
The whole audience could see it, could hear that difference.
It was his approach, note choice, vibrato, ability to sustain notes with his hands rather than obnoxious amounts of gain and volume. It was all just really well thought out and seemed to just happen 'naturally', although I know that almost casual delivery of something absolutely amazing came from decades of dedication, playing hours a day, excellent music theory knowledge, incredible technical ability and having a defined musical personality.
I know I'll never attain that level of guitar playing, none of us will here.
But the stuff to work on is all of the above.
Worry about the gear less.
If you have the stuff in bold down then it doesn't matter so much what equipment you play.
Your musical personality will come out regardless.
Work on that.
Football is rubbish.
At home , I'm now playing my amps through a Fryette PS100 and live the band plays direct to FOH and I use a Victory V4 pedal amp, soon to be replaced by a Friedman IR-X. I couldn't be happier.
