It’s useful for a few reasons - as a backup if the main jack gets damaged, to better match the output of an active instrument (both for volume and impedance), it allows you to run two instruments into the same channel (not that it’s very likely) and most usefully for modern players, you can use the second input as a splitter output to jumper the channels, or to another amp.
I don’t find it essential, but overall I’d probably rather have it than not, and it only adds a tiny bit of cost.
It's convenient, and I do miss it now that the DSL has taken over.
My trading feedback: https://www.thefretboard.co.uk/discussion/210335/yorkie
It’s even more pronounced on my Marshall JCM800 though. I’ve ended up using almost completely different pedal boards depending on if I want to use the high or low inputs.
