SOLD!! Source Audio True Spring reverb+trem pedal |SA favourites switch | £190 posted
Being unfeasibly attached to the old school effects of reverb and tremolo, I'm always on a search for great pedals to interact with my non-effected amps. I believe the True Spring reverb is one of the finest recreations of the classic sounds with short, long, and tank options - t
ogether with tremolo effects straight from SA's own Vertigo pedal. And these are top quality trem tones; having everything in one pedal (which is smaller than a Strymon Flint) is a real plus.
Sold with the True Spring is a Source Audio favourites footswitch which allows you to toggle the trem sounds at will - and do various other clever things I'm too impatient to explore, including switching between the reverb types. And as you can see, a swift hook up to your laptop allows access to Source Audio's Neuro tone programme for even more presets. The True Spring may also be run in stereo.
https://i.imgur.com/1zylSIu.jpghttps://i.imgur.com/EMOpseF.jpghttps://i.imgur.com/YjFqjp8.jpgThis is a clever tweakable pedal which sounds great across a range of tonal possibilities, but can also be used in a totally straightforward way. You need it.
https://i.imgur.com/AwiR7ug.jpghttps://i.imgur.com/GydHhWV.jpghttps://i.imgur.com/5v0dJmV.jpgOriginal boxes now located for both pedals, and as anyone who has bought from me will know, I will pack with care and post with speed. I'd like to see £190 via PP F&F (including UK postage) for this fine pair of additions to your pedalboard.
https://i.imgur.com/zVqhQqM.jpghttps://i.imgur.com/P20piLF.jpg
