I've just bought a s/h Peavey Bandit 112, fairly new-ish, and although the clean and lead tones are (to my ears anyway) pretty good direct from my Strat, thought I would see how the GT-1 sounded into the front of the amp (I've not used the effects loop, wouldn't know where to start).
What is the consensus - disable the pre-amp on each of the GT-1 presets, and go through the Bandit clean channel, which is currently set up with Low 7-9, Mid 6-8 and High 3-4? Or leave the pre-amps on and set up the Bandit differently?
I love my brick
I've just spent some time adjusting the levels between presets to try and get them roughly in the same ball park, so at the same time took your advice and tried with and without pre-amps, on the whole they tended to sound better with on the crunchier/ lead tones, but worse on the cleaner ones.
Don't forget that on the GT1 you can change the output options to match the kind of thing you're connecting to, as that will then alter output levels and colour the signal differently.
Yeah, good advice - it's set on Combo Amp so think that should be ok. Cheers!
My Bandit clean channel is in Classic mode, and I’m only playing at home with the amp not too cranked.
