Nashville to ABR-1 Black conversion posts
EynonjEynonj Frets: 45
Hello!
Looking to amend the bridge on one of my guitars to an ABR-1. I've seen that there's conversion posts around, but they all seem to be in either Chrome or Gold.
Can anyone point me in the direction of black conversion posts or a way that I'm able to convert it to an ABR-1 in another way?
Cheers!
  • guitars4youguitars4you Frets: 14842
    Try Jon @FelineGuitars  - and/or check out his website listings
  • elstoofelstoof Frets: 2590
    If no one makes a black conversion post, the alternative is to pull the pushings out, *plug* the holes and screw in a pair of black ABR1 posts
  • FelineGuitarsFelineGuitars Frets: 11769
    Sadly all nickel or gold in that style…Faber ones
  • NCoNCo Frets: 168
    edited November 2023
    FYI, the Faber ABR fit the Nashville studs on my Gibson LP Studio without changing the Nashville posts that came stock.
    Depending on the guitar/spacing/ABR bridge, you might be able to simply buy black Nashville posts and slot an ABR bridge on it.
  • Philly_QPhilly_Q Frets: 23751
    NCo said:
    FYI, the Faber ABR fit the Nashville studs on my Gibson LP Studio without changing the Nashville conversion posts that came stock.
    This is true, if it's a Nashville with the small 4mm posts an ABR-1 should fit.  If it's got the wider slot-headed posts you're out of luck.
    Be careful quoting nashville posts and spacing as they are a fair bit different to ABR-1
    Here is the Faber guide and the models for each option
