Les Paul pot shaft question
On changing knobs on my ‘97 Orville LP, I managed to completely pull out the bridge tone shaft which was a presumably non-original coil-tapped pot. The others are a bit noisy so I’ll probably replace all 4 pots. The volume ones are also short shaft - just checking there’s no advantage to replacing them with long shaft versions? Thanks in advance for any guidance.
  • FelineGuitarsFelineGuitars Frets: 11978
    The only reason to go with the long shaft ones is if you need them to get through a deep top on a guitar , but it sounds like the Orville is routed deeper and doesn't need them
  • scarry67scarry67 Frets: 144
    Thanks. And well done for avoiding any innuendo…
