I built this for
@PhilKing some years ago to match a full size SG style
It's fun, but I went for a mandolin scale length of 14 1/4", which is especially tight with all 12 strings
So we have decided to extend the scale, which will involve a new fretboard and the bridge moving back a bit.
First step, iron off the fretboard
An old kitchen knife and domestic iron gets us there in about 15 minutes.
I've made a laser cut template with an increased 16 1/2" scale length
That will obviously give less frets, but much more usable spacing
The bridge will need moving back to match. This shows the new spacing.
but it is certainly useful, its marked out 4 fretboards this afternoon, none of which are standard scale lengths. This one is on the right.
Instagram
Can the laser cut the actual slots the right width as well or is it really only being used for marking?
If I did cut them to an accurate width there is a risk of weakened charred edges to the fret slots, if I cut them to accurate depth the settings would be different for every piece of wood. Better to just score a line and finish off with a saw, it only takes a few minutes to get them correct.
I could also cut the boards out, but again prefer to trim with bandsaw and plane to the engraved line
none of these 4 boards were standard scale lengths
Instagram
I use an old kitchen knife as I find it works better than the proper seam separation knife I used to use, although i often start it off with that.
Instagram
