Vox AC30-C2 BL - Limited edition Vox AC30 in blue for sale - £450
The amp is in excellent condition and has never been gigged. There are some minor scuffs/scratches (please see photographs). Recently serviced by Morris Guitar Amplification Wood Green - pots cleaned and electrics checked.
Fantastic amp that has served me well over the years. Selling because I have upgraded to the Handwired AC15HW1X which betters suits my needs.
Collection from North London preferred, I am also open to offers. Please message if me if you have any questions.
Original spec/product description -
The AC30C2-BL is covered in blue vinyl in the traditional Vox "basket weave" pattern. The amp featured "Tygon" grill. The corners, vents, handles and knobs were off white. The amp featured two 12" Celestion Green Backs.
VOX Custom Series amps offer two channels, Normal and Top-Boost. Each channel is equipped with its own volume control. The Top Boost channel offers highly interactive treble and bass controls. This powerful channel pairing provides an abundance of tone-crafting control, letting you dial in a classic sound that is all your own.
Both channels rely on the Tone Cut and Volume controls in the Master section. The Tone Cut control operates in the power stage rather than the preamp stage, allowing an additional degree of tone-shaping. The Master Volume control works in conjunction with the individual volumes of each channel to create just the right degree of gain-staging. This VOX Custom Series can deliver everything from a clean VOX "chimey" sound to a powerful overdriven tone in a limited edition blue package.
Sound in Motion
You can sweeten the sound of your Custom Series amplifier using the VOX Classic Tremolo effect. Both the speed and the depth are adjustable, allowing you to generate just the sound you want. Spring reverb is also included on all Custom Series amps, adding spaciousness to the sound. The VOX AC30C2-BL also includes an additional tone control in the Reverb section. All Custom Series amps can use the VOX VFS2 footswitch, allowing you to turn the reverb and tremolo effects on and off as you continue to play. The AC30C2-BL provides an effects loop for incorporating your favorite effects into your sound. True "Bypass" switching takes the entire effect loop out of the circuit.
Power Sharing
The AC30C2-BL amp make use of three 12AX7 preamp tubes and use four EL84 tubes to deliver 30 watts of power. The AC30C2-BL uses two 12" Celestion G12M Greenback speakers. All models in the Custom Series offer a switchable 8/16 ohms output jack for powering an external speaker cabinet when you need to speak with a little more authority; using this jack will mute the internal speakers. Additionally, a second extension speaker jack allows you to run an extra 16 ohms cabinet along with the internal speakers for a fuller sound.
Features
3 -
- 3 - 12AX7 preamp tubes 4 EL84 power tubes
- 30W
- Normal and Top Boost channels
- 2 - 12" Celestion G12M Greenback speakers
- Spring reverb effect
- Tremolo effect
- Top Boost input
Specs
- Dimensions: 27.64 W x 10.43 D x 21.89 H
- Weight: 71 lb.
- 30W RMS
- 2 x 12" 8 ohms Celestion G12M Greenback speaker
- Inputs: Normal, Top Boost, FX loop return
- Outputs: external loudspeaker jack, extension loudspeaker jack, FX loop send jack
- Options: VFS2A Footswitch sold separately
