There's also far too much wrap on the E, the string should not be overlayed on itself like that.
Try to keep the wrap to about one complete turn on the E, two or three on the A (all below the sticking-out end), and if there are string trees on the D and G (obviously there are on your guitar) also about one turn.
Best is to do the 'half back turn and lock under' wrap method which means the strings won't slip even with as little as one turn on the post.
