Hi low-enders,
I was just wondering if anyone here uses anything to reinforce their bass sound.
I use Sire active basses with a Roland Bass Cube 120XL and prefer the Session model, which is based on an SWR - it's a nice rounded sound that allows for slap and popping without being harsh. I sometimes use a little compression, too, but it's lacking something and at this juncture, I'm happy with the amp in terms of size, portability and volume and so I'm thinking more in terms of preamp pedals or EQ rather than swapping it.
I do have a Zoom B1xON that I sometimes introduce but that's more for home. Also, I recently took delivery of a HX Stomp which I've get to get to grips with and so that might be a solution but I was also thinking of units such as the GK Flex, EBS Microbass III etc.
What enhancers do you use?
Thanks
https://kottracker.com/
The only effects I use/ I'd add are a compressor (Ego) and EBS Octaver and possibly, an EP Boost.
I must say, ordinarily, I'm not a fan of the Ampeg sound and that tends to be the backline where I'm not taking my amp and I struggle with them but..there are an industry standard. I did, however, find the Tech VT Bass 500 to be very good and very versatile but I think they've been discontinued and I don't need the 500 watt amp.
Any EBS Microbass users? @prowla - Paul, I didn't try one at the BassFest but I see you're a user.
What about HX Stomp users? Could I be covered there and anyone using just that to an FRFR or FOH?
I tweak from there.
I always add a tiny bit of nasal drive. Sounds horrible on it's own but in a mix it just adds harmonic content.
I have 2 amps - the Ashdown RM800 Evo2 and a Mark Bass AG1000. They are very different sounding amps.
I always use a compressor and I usually have an Octave available too - not just for an obvious effect but sometimes as a very subtle thickener. That works best when there's a HPF after it to stop octave'd E-A notes getting through to the amp and making everything sound like arse.
Over the holidays, I need to become au fait with the HX Stomp for my main guitar pedal board and once I learn how to use it, navigate things, I'll look into the bass side
Try the hx stomp into the amp. If you dont find any magic then a higher quality amp may be the ticket. Have you ever played a Markbass mini 121 or 151? They'll most likely give you that "something" extra.
Funnily enough, I played a gig/show the Wednesday just gone by and there was a hired in backline and the bass amp was the Ampeg SVT Classic head and 4x10 cab. Once again, I know it's an industry standard but I'm not a fan of the Ampeg. I sort of fixed the sound to suit using my Zoom B1xON using compression, some EQ and a Hartke head model and it sounded decent but I know that same preset combination has not worked on the modelling of the Roland.
I will get myself to Andertons and try the TC Spectracomp, the EBS Microbass III and some other amps, including the EBS Magni 502 which has come down in price but is still £900.
Thanks everyone for your comments and suggestions and of course, I will give the Stomp a good go, too.
I'm still trying to get to that place but before I look at other amps and I wanted to see if I could 'fix the sound' with my existing amp or am I trying to put Ferrari Wheels on a Ford Fiesta?
Any users of the above pedals?*
** Also posted over on BassChat where I'm also a member**
As a heads-up, Amazon are doing the Behringer BDI21 for £19.48 as that was also suggested to me on BassChat.
@Lawriejones1 - I know London theatre pit player, Ian King (Hamilton etc) rates the Stanley Clarke one and he doubles up, using it for both his Upright and Electric basses, but if I've understood correctly, are you're using it for Bass and Guitar? If so, could you please elaborate on the guitar bit i.e. just for cleans or as a pedal platform?
Its a simple but powerful EQ and the high pass filter is really effective, too.
I found the pre amp is much more responsive than many of those you’ll find in bass amps and it means I can dial in the tone I need really quickly. Of course you can also make adjustments really quickly on gigs when needed too.
One of the issues with using lots of effects is that it can suck out the bottom end a bit so consider that. I found the EQ pedal helped.
One of the main reasons the Stanley Clarke pedal is so good is because of the inbuilt HPF. If you’re not playing double bass you won’t need this so definitely try cheaper models and options until you find something that works.
