The Milkman 100
DavidReesDavidRees Frets: 337
any experience/wisdom to be shared from fellow Fretboarders?
  • nero1701nero1701 Frets: 1545
    edited November 2023
    I have one,
    Really like it, crystal clear cleans, Depp cavernous reverb (or none) bass and treble adjustments are impactful from the slightest tweak.
    Built in boost is very good, great as an always on, or as a proper bump.
    Build quality is fantastic, there are some dip switches inside to change reverb effects from plate to spring ect.
    I'd say its my No. 2 after my princeton,  but...vwry similar in sound. .
    Line out with cab sim, headphones out and 4-16 ohm speaker out. Can also be used as a pedal.
  • It is superb.
    Captures that warm Milkman sound and feel.
    loved mine
  • BabonesBabones Frets: 1209
    I like mine. Decent reverb and the boost adds midrange. I like 'simple but good'. I use it as a pedal platform (for dirt). I don't much care for it's pedal format however. I'd prefer it in a conventional head format.
  • TeleMasterTeleMaster Frets: 10398
    Yea an amazing amp. Definitely worth the money, especially used if you can find one. Takes pedals amazingly, sounds great just turned up with natural amp gain and it's tiny. You can't believe that it is that small with actual tubes in it. It's the future.
  • Excellent piece of kit. I did try other pedal sized amps at the time I bought it, and it was way better than anything else. I also preferred it to the Milkman 50, particularly as the extra features were of value to me.
    I wish it had the trem of the 50
  • FortheloveofguitarFortheloveofguitar Frets: 4293
    Never heard of this so went and had a look on YouTube. Now I want one, sounds fantastic for clean and edge of breakup tones . Impressed!
    Selling one  ;) in classifieds..
  • gatheredinsonggatheredinsong Frets: 681
    I'll echo what others have said. I mostly run mine into a 1x12 cab housing an Alnico Cream, sounds good at all volumes.
    Image of mine testifying that it takes pedals well
    https://i.imgur.com/E7dBWfl.jpeg
