Clean end or dusty end?
TanninTannin Frets: 5614
How far up the neck do you go?
* EVER: the highest fret you *ever* use in normal play?
* SOMETIMES: the highest fret you *regularly* use  in normal play? (More than just one or two songs even if you don't go there all the time)
* OFTEN: the highest fret you frequently use in normal play? (Most songs take you this far up)
* ROOT: how much of your time do you spend in the root position? (Open strings and traditional first-three-fret chords)
(Acoustics only, obviously. Electrics is a different instrument, and you'll have different answers.)
  • TanninTannin Frets: 5614
    EVER: 14th, and that seldom
    SOMETIMES: about the 10 or 11th, give or take
    OFTEN: 9th
    ROOT: depends on what I'm playing, but probably 50-60%
  • DavidRDavidR Frets: 778
    edited November 2023
    Hardly ever above 12th. Usually below 5th
     In mathematical terms, I would imagine the percentage chance of finding my left hand a specific distance from the nut is roughly 100 divided by the distance in cm, squared!
    So % chance = ~100/(distance in cm)squared.
  • munckeemunckee Frets: 12505
    As far as I can although I'm more a strummer so mostly open/barre chords.
  • deejayendeejayen Frets: 15
    I kind of just noodle around at home, but often hit the 17th fret with a double-stop.
    Full chords are harder, and I've had to truncate one I play on the electric with four strings to three strings on the acoustic.
    Last night I found myself at the 20th (another double-stop), but it's hard to hit it first time as it needs a change of arm/hand position, and I'm not always anticipating landing there!
    So, I suppose:
    EVER: 20th
    SOMETIMES: 17th
    OFTEN: 12th/13th
    ROOT: Probably 60%
    I should say that this is on a Gibson LG-2 with a 14th fret neck joint and no cutaway.  I've been thinking about guitars with a 12th fret neck joint - presumably these would limit things, but it might be okay with a change of technique!   One 12th fret guitar I considered does have a cutaway, but as I can't remember playing an acoustic with a cutaway I'm not sure if they help much, as presumably there's still a big lump of something which could get in the way.
  • I go past the fretboard.
    Lol
  • sev112sev112 Frets: 2839
    I’m playing a load of fingerstyle Xmas solos at the moment that use harmonics at 19th quite a bit
    Simpler solos I play around root a lot, but in DADGAD I’m always “based” between 2 and 5.
    more of my more complex solos seem to base me at 7 and 9 with pinky going to 12 or 12 harmonics, with a occasional 14/15 on the high E
  • SOMETIMES: 14th
    * OFTEN: 12th
    * ROOT: Not a lot
  • On acoustic I'm fairly evenly spread across the first 12. Occasionally 14 or 15 but basically never higher. Cutaways are the devil's work.
  • bertiebertie Frets: 13577
    Wins the interwebz  today
    I play all over the shop all the time  - there is no "regular",  often use a capo (as in every time I play, but not for every tune)  sometimes two (for those "pseudo drop Ds").
    so probably 15 is the highest Id ever go, but not often - and purely based on physical restriction
  • KilgoreKilgore Frets: 8601
    Ever: 14
    I favour 12 fret guitars so a fairly even spread up to 12.
  • UngulateUngulate Frets: 237
    Not a Taylor fan then  =)
  • droflufdrofluf Frets: 3872
    EVER: 14th, but very rarely.
    SOMETIMES: 12th, but mainly for harmonics
    OFTEN: 7th - 9th
    ROOT: rarely, more often 2nd-5th - which may be in your definition of root?
    That’s fingerstyle, mainly in DADGAD
    Ive owned two,  me neither - ish   - tho the original babys (rough frets aside) /big babys are great fun as a couch guitar
  • KurtisKurtis Frets: 796
    I probably don't go above the 8th much, maybe 10 or 12 at most generally.
    A large chunk of my acoustic playing is open chord strumming. At least 50%.
    EDIT - I'm not really a fan of cutaways either.
  • ICBMICBM Frets: 72944
    Ever - 17th I think. I can’t remember playing anything above that in a song, although I play right up to whatever the last fret is when I’m just doodling around.
    Sometimes - 15th. I like the open G shape an octave up.
    Often - probably 9th-10th, depends on the key.
    Root - probably 50%. The open chords are a foundation, the high stuff is for contrast.
  • GTCGTC Frets: 267
    Ever - 20th
    Sometimes - 14th
    Often - 10th
    Root - 40% - 60% (dependent on piece)
    I haven't considered artificial harmonics in the above answers
    That is similar to me. I like the open E shape played on the 13th & 14th frets and use it reasonably often. Never tried open G shape up there, might be a bit hard to reach without a cutaway.
    I slide that same shape down two frets for a D (with a 7th (E) in the bass) and the C#m7/E a fret further down (0 11 11 9 0 0)
    PS: I just tried the open G you like. Tricky to reach and not a sound I care for on first impression - but sometimes these things grow on one.
  • ESBlondeESBlonde Frets: 3597
    EVER - probably 15th and then only top three strings
    SOMETIMES - again 15th, top G etc. and D shape
    OFTEN - 10th across all strings
    ROOT - in singer guitarist mode probably 40% but a lot of moveable chords and barre chords to get the voicings nice and lots of songs in keys like Eb or Bb.
    ESBlonde said:
    in singer guitarist mode ...  lots of songs in keys like Eb or Bb.
    Masochist!
    Tannin said:
    Masochist!
    Ha! If I ever introduce these songs to the band the basserer rolls his eyes and utter things like “Oh no”.   ;-)
