I saw this going quite cheaply in an auction and couldn't resist.
It's a Hohner Orgaphon amp from, I guess, the mid Sixties. In typical German fashion it's incredibly over-engineered compared with British or American amps of the time. Big and heavy but from memory not as heavy as an AC30.
The preamp and reverb are mounted in the top part of the amp, the power amp and power transfomer are at the base of the cab. There are five separate input channels! The first four have duplicate inputs on jack sockets and DIN sockets:
Looks like there's a sixth input on the lower board that goes straight to the power amp. Bizarre external speaker connection options -- they're switchable for 16Ω or 4Ω but not 8Ω, and use what looks like an old hi-fi connector. Love the on/off button.
The power amp tubes are, I believe, PL84s, which was a type commonly used in TVs. I guess they used the same chassis for another model with four of them. Anyone recognise the speakers?
It has spring reverb and tremolo, with separate footswitch inputs. The architecture is more like a mixer than a conventional amp. There's a master reverb level control and each channel has its own reverb send, which I think is pre-gain, so if you turn the channel gain all the way down and the send all the way up, you just get reverb.
The five channels all have different controls and presumably different purposes. Tremolo is only on channels one and two and is activated by pulling up the gain pot. Channel two seems to be a low-impedance input as it sounds very quiet and dark with guitar. Channel four just has a gain knob, and there are no controls on the 'tape' input which is channel five.
I've fired it up briefly at home and it's an interesting amp for sure. It seems a bit noisy so could possibly do with a service. The tone controls on channel one interact in a strange way, it's quite hard to find the sweet spot but there are some good sounds to be had. Channel three is probably the best sounding for guitar. It will distort if you turn the gain all the way up but was obviously designed as a clean amp. Tremolo is great and the reverb seems pretty good.
I'll drag it to the studio later this week and spend a bit more time with it.
I removed the rear baffle to take the internal photos -- with it in place there wouldn't be any way to touch anything internal whilst it was powered on.
Still wondering about the speakers. The bass sounds quite tight, but they're obviously putting out some sort of super low frequency thump on low notes -- you can see the grille cloth being blown in and out. Not an amp you'd want to put a ribbon mic in front of.
Anyway I think these are probably the last 'vintage' amps that are still affordable. If it said Selmer or Ampeg on the front you'd be paying a lot more.
The speakers are probably made by whoever were the German equivalent of Wharfedale or similar.
Ignore the PAT sticker, they have been widely available since the 1990's & being filled in by hand, prove nothing.
