If you don't have a multimeter to test it, you can do it with the amp... first identify which of the leads is the return - it should be the red cable connected to the output of the tank, but isn't always if someone has been at it already - and touch the tip while carefully turning up the reverb, it will buzz loudly. Once you're sure which is the return connect that to the output end of the tank and shake the tank - if you get the usual reverb crash, the output is working. Then connect it to the input end and shake again - if that also crashes (quieter) then the input end is also OK. If one end doesn't work (usually the output) they can sometimes be repaired fairly easily, but replacements aren't that expensive.
It was excellent. Way better than the following Valvestate models.
