As pleased as I am with Dark Terror mine has quite a noise effects loop, I've got two pedals in the loop, a Behringer DR600 reverb and an Ibanez analogue delay. Off they seem quite as soon as one is on (either one) its gets a low level white noise. I've tried the amp clean so the gain isn't causing it. Changed the send/return cables and tried one or other of the pedals only. I haven't tried anything else yet as I need to have a little read up and ask here etc.
Can I jumper the loop to see if it still does the noise or will that cause problems of its own? ( i'd imagine its fine as thats what the loop is with pedals off isnt it? )
Possibly the valve ? Its a ECC81 buffered loop , at 22 quid for a JJ , whilst not that expensive I thought i'd check first.
Jumpering the loop with a cable won’t do anything, since the loop is switched directly via the jacks anyway.
I don't recall either pedal being noisy when I ran into the quilter but then I only ran them into the front.
An excuse to search for a reverb then (as if I needed an excuse)
I remember a couple of those Behringer plastic pedals I had once (a bass limiter and a graphic eq) being noisy in a similar way, a low level hiss whenever switched on.
Having the loop after the final master volume causes three problems - it’s difficult to get the signal level right without causing potential clipping issues with low-headroom FX because it’s dependent on the master volume setting; at low settings the signal is weak compared to any noise from the FX; and you have no volume control on the amp if you’re using the FX return as a power amp input.
A quick fix for this would be to put a passive volume box in the loop after the pedals, turn the master volume up, and control the volume with the volume box.
Watch the parking meters
Ibanez in front on its own - fine
behringer in front on its own - fine
ibanez in loop on its own - noisy
behringer in loop on its own - noisy
i tried minimal gain and max volume on both the 15 and 7 watt settings and its humming like my grandad in church on a sunday
to conclude , the loop is a noisy bugger. I like the loop though so has anybody else got a Dark Terror that does or doesnt do the same? Or is there a simple fix for this? Other than not running the pedals in the loop (seems a shame)
