This Multiscale 7 string Ibanez RGD71ALMS electric guitar combines two scale lengths in one guitar both 27" and 25.5". This allows a more natural and balance string tension across the strings gauge for better tuning, intonation and playing experience.
The 'fanning' of the frets along the length of the Macassar Ebony fingerboard help with the natural finger positions as you sweep across the fingerboard, again aiding more natural playing feel
Designed for both stability and sustain, the innovative Ibanez Mono-Rail bridge minimizes cross-talk between strings.
Macassar Ebony fretboardMacassar Ebony produces tight lows and mid range along with strong attack in the highs and quick response with rich sustain.
Sub Zero Treated FretsThe Sub Zero treated frets can stand up against the hardest riffing and string-bending.
Fishman Fluence Modern Humbucker pickupsThe Fishman Fluence Modern Humbucker pickups provide an aggressive tone and a powerful attack without excess noise.
Multi Scale NeckThe multi-scale neck utilizes an equalized string tension, creating a more “open” or “alive” tone that not only expands harmonic complexity, but also offers a more comfortable playing experience.
Nitro Wizard 5pc Panga Panga/Walnut neckSuper-thin and ultra-playable Nitro Wizard 5-piece Panga Panga/Walnut neck substantially increases sustain
Luminescent side dot inlaysThe luminescent side dot inlays make it easy for players to perform on dark stages, matching the dazzling luminescent Ibanez headstock logo.
Schaller S-Lock strap lock pinsIndestructible Schaller S-Locks don't fail, even under the toughest conditions on stage.
Gotoh MG-T locking machine headsThe Gotoh MG-T locking machine heads achieve incredible tuning stability, cutting down string-changing time.
owned for a about a year, not used much was an impulse purchase.
https://postimg.cc/gallery/ZBgVwcH
Radius: 15.75"(400㎜)
with String Thru Body
3 Way Pickup Selector
