Greetings folks,
Doing a spot of spring cleaning (i.e. sorting out a load of crap I no longer need), and I found a couple of valves I must have bought a while back. I'd like to know if there's anything they are likely to be useful for and also if they're likely to be worth much more than a couple of quid?
Valves in question (there's only 2) :
a Mullard ECC82
a CVC ECC81
Visually they look in good nick, but I have no means of testing them short of sticking them in an amp if it happens to be suitable. I need a new electronics project, so if they *are* usable in an amp circuit then I'd be keen to know.
Ta muchly,
Adam
The ECC83 and ECC82 are both rated for 250V - it’s just the ECC81 and the 12AY7 which are only rated for 90V.
In Fender amps, yes - most others don’t.
I think the Mullard ECC82 should be worth about £20 if it tests good - they’re nowhere near the value of a ECC83.
The CVC (Chelmer Valve Co - an importer not manufacturer) ECC81 is probably a 90s Chinese valve and worth a tenner or less.
Out of interest, the CVC ECC81 had no other markings on it - not country of origin for example.
Cheers,
Adam
