I was hoping I could just push the grill cloth out a little and tap out the t-nut but I've just realised that there's a piece of wood on the baffle covering the front of this particular t-nut - the piece where the '100' logo attaches. It's a 1982 cab.
When I’ve had to fix this - more than once - I’ve simply got a separate speaker clamp (the sort you find on front-loaded PA cabs) and a large self-tapping screw, and screwed it to the wood next to the broken bolt. Yes, it means one new hole in the cabinet. But I’d rather that than try to drill out and re-tap an extremely rusted T-nut.
Would you mind posting a pic or a link to tjat speaker clamp? I'm not familiar with them.
Something like this -
https://www.flightcasefittings.co.uk/g0726-plastic-speaker-clamp.html
There are simpler metal ones too, but mostly only seem to come in sets of four.
https://www.ukdj.co.uk/stands-cases-c4/accessories-self-build-c345/fixings-c352/eagle-altai-set-of-4-heavy-duty-speaker-clamp-kit-inc-t-nuts-and-bolts-p5048
I have a number of spare ones if you prefer!
I think the best bet if you are determined to get it out is to drill as much of the bolt away as you possibly can, then see if you can get a tap - it's 2BA (not M5) to follow the thread in the T-nut and clean it out. Bearing in mind it's now a blind hole because of the wood across the far end.. although you could go into that a bit if you have to.
@CampbellH As ICBM has said, I can't see the screw coming out - it was very difficult to turn.
I may as well try to drill out as much of it as I can & then tap it, but I'm quite sure I'll be using the speaker clamp method above!
