Strange out of phase issue - Gold Foil
photekphotek Frets: 1472
Popped a lovely Mojo Goldfoil in the neck position of my tele… of course it was out of phase.
Swapped the bridge pickup hot and ground and no sound at all from the bridge pickup, neck worked fine. Hmmm.
Swapped the bridge wires back and reversed the hot and ground on the gold foil. Perfect, in phase, sounding lovely…. Until I touched the cover of the gold foil which now buzzes like a bastard.
Swapped the GF wires back and no buzzing but out of phase.
What am I missing or do gold foil pickups need a specific polarity bridge pickup to pair with?!
Pic because it’s pretty:
  • PhilKingPhilKing Frets: 1520
    Did you disconnect the grounding wire to the baseplate of the bridge pickup before you swapped the wires around?   Sounds like you didn't and I think that would give you the no sound issue.
    btw, great looking Tele
  • photekphotek Frets: 1472
    Ahh, it doesn’t have a separate ground on the baseplate, assuming it’s combined with the normal ground wire. I guess that means I can’t use that bridge pickup in phase with the GF?
  • Paul_CPaul_C Frets: 7952
    You can swap the wires on the bridge pickup if you swap the wire that earths the base plate to the other wire.
    httpsguitaranatomycomwp-contentuploads202305DSC00429-scaledjpg
    Ahh nice one, I will give that a go thanks both :+1: :+1:
  • blueskunkblueskunk Frets: 2929
    Lovely Tele. Good luck. Great place this for such advice.
  • ICBMICBM Frets: 73359
    You either need to swap the ground connection on the bridge pickup baseplate to the other eyelet, or separate the ground from the pickup completely, with a separate wire.
  • OilCityPickupsOilCityPickups Frets: 11216
    People always seem to get in a fix with Tele baseplate earths. There is no real reason the coil start or finish wire needs to be connected to the baseplate at the pickup end ... apart from ease of manufacture and neatness. Just snip that short connecting wire and solder a nice new earth wire between a pot back and the baseplate ... job done.
    Thanks all I will sort it tonight, funny that I haven’t stumbled across this before in all these years, lucky I guess.
    I knew I could count on the forum to help :+1:
  • p90foolp90fool Frets: 32125
    That's probably safer than potentially overheating the eyelet solder too.
    Absolutely ...
  • Philly_QPhilly_Q Frets: 24004
    Just to come back to that bit, the cover probably shares the (original) ground wire - like a Tele neck pickup.
    edited February 11
    All sorted, snipped the baseplate ground wire and replaced with one running to the back of the volume pot. Sounds superb and no buzzing when touching the Goldfoil.
    Thanks very much everyone 1 :)
