Prototype Mustang / Jaguar Hybrid Tremolo
maw4neumaw4neu Frets: 579
edited March 31 in Making & Modding
Just need to work out the best place for the Tremolo Arm . . .
To the RHS mimics the Jag/Jazzmaster but to the REAR is better in terms of mechanical efficiency . .
https://i.imgur.com/NU53g59.jpg
https://i.imgur.com/U1Z4CPq.jpg
Should have it sorted soon . .
Id just like to point out that, despite all the video and DNA evidence, it genuinely wasn't me, your Honour  !
Feedback : https://www.thefretboard.co.uk/discussion/58125/
  • Looks interesting. Let's hope you avoid the arm and collet rubbing on the strings like the new Guild Surfliner does!
  • maw4neumaw4neu Frets: 579
    edited February 7
    Just checked the Surfliner out and the chap reviewing the Guitar pointed that very issue out . . .
    If your going to pivot the Plate, off centre then your asking for trouble . . as I mentioned above to the RHS mimics the Jag/Jazzmaster assembly but staying on the centre of the Plate, but behind the screw that tensions the Tremolo is way better in terms of mechanical efficiency . . it also stays in position better  . . .
  • ICBMICBM Frets: 74041
    Very neat. I think it would look, and most likely work, best with the arm socket halfway between the bridge and the string anchor, and on the centre line.
  • FunkfingersFunkfingers Frets: 15092
    IMO, the spring and mechanism should be along the centre line, between the D and G strings. This would oblige the arm and collet to be off-centre, between the B and E.
    I'm fairly sure there's enough space between the spring and the string anchor to fit the arm collet on the centre-line as well - in fact, right about where the existing hole in the plate is, or a little further back.
    edited February 8
    Our Laser Dept. is running flat out this week so I'll have to sneak my little Hybrid Plate in next week sometime when its a little quieter. Im trying to keep and machining or additional holes down to a minimum but the 2 holes at the rear of the plate were compromised so Ive had to reposition them elesewhere, plus I'm looking at 2 more fixing holes as the stock Jag / Jazzmaster Trem has 6 x fixings . ..
    The Plate that is eventually fitted to my Squier Mustang will have a shot blasted finish . . .  I was thinking of fitting it to my Jagstang, but on balance, Ill keep that as it is . . I like that fact that the Jagstang Bridge is fixed . . . Ive used the Jagstang at Band Practice and its quite a versatile little guitar . . .
  • DrBobDrBob Frets: 3035
    That’s all sorts of awesome, any plans to make a few of the plates ?
    100% yes  . . .  once I'm happy with the outcome, I'll have a few made, maybe 10 . . . the plate is the easy bit really . . I've had to buy a cheap Chinese Jaguar Style style Tremolo to harvest the Trem Arm, the Collet, the Backplate and the Spring assembly . . it was £18 off eBay . . . .  The plates will be shot blasted and I'll sort out any countersinking etc.
    edited March 31
    This is my second bash at the Tremolo . . . it works well and operates quite smoothly but I've sold my Mustang's now and I dont really want to fit it to my Jagstang as it will most likely devalue the guitar . . .
    Ive got enough spares to make one more so if theres a guitar builder / hobbyist who wants to make me an offer for this one or the other ( without a Tremolo Arm ) then I'm all ears :-)
    https://i.imgur.com/j5FMWXe.jpeg
    https://i.imgur.com/v2ikWxW.jpeg
    https://i.imgur.com/QwZuG3j.jpeg
    Calling @DrBob ; . . .  if your still interested :-)
    Definitely interested message me
