QQ for GT-1000 users
Just a quickie...can someone who has a GT-1000 tell me which amps are being used on the preset 'Premium Drive'? Is there a resource which goes through the settings on these preset patches? I have a GT-100 and I heard someone using this patch on the GT-1000 and I was interested to try a similar setup.
Thanks!
  • fnptfnpt Frets: 763
    2 X-Hi Gain in parallel with a treble booster in one of the paths. Both have different eq's as well,
    ____
    "You don't know what you've got till the whole thing's gone. The days are dark and the road is long."
  • vasselmeyervasselmeyer Frets: 3681
    It's two switchable paths.
    Path A:
    Amp x-Hi Gain
    Gain 70
    Sag 0
    Res 0
    Lev 50
    Bass 80
    Tre 50
    Mid 50
    Pres 40
    Gain Mid
    Path B
    DS1 Treble booster
    Gain 55
    Ton -5
    Lev 50
    Amp X-Hi Gain
    Gain 100
    Sag -5
    Res +8
    Lev 70
    Bass 45
    Tre 50
    Mid 50
    Pres 50
    Gain Mid
    If you switch the divider then path A is your rhythm and path B is your lead with the bass cut, the gain increased and the booster in front. It's a cracking patch.
    Note: there's also a parametric EQ block after each amp which are very slightly different, but to my ears they don't do much at all. I can get the setting from them if you want.
  • gearaddictgearaddict Frets: 898
    Thanks man, that’s great!
