https://www.charvel.com/gear/shape/so-cal/style-2
Or a fret king country squire. None of them have a p90 but both are coil tappable. Vari coil on fret kings is a great thing.
EDIT: no belly cut on the FK though.
https://www.pmtonline.co.uk/schecter-svss-pt-fr-sea-foam-green-electric-guitar
I have a Schecter PT type, but it's not one with a trem. This is the one I have:
https://www.schecterguitars.com/Hellraiser-Hybrid-Pt?quantity=1&custitem_color_master_list=220
Slightly over budget new, but should be able to get a used one well within, if you can find one.
https://www.guitar.co.uk/reverend-pete-anderson-eastsider-s-satin-black-roasted-maple
It would be possible - if expensive - to suspend a Greg Koch Gristle Tone bridge pickup via an adapter plate. The wiring might prove tricky because the Classic HB has three modes but the GKGT has just two.
Chapman Guitars standard series ML-3 Traditional is available with a P90 in the neck/Rhythm position. Retrofit your preferred vibrato.
