T-Rex Moller2
snowblindsnowblind Frets: 576
Just fired up the Moller with this little lot. Sounding really rather good. DR103 with 6x12 speakers plus a BC30 2x12 split through a Radial ABY, T-Rex roommate reverb and a bit of delay into the HiWatt from the Alter Ego X4.
https://drive.google.com/file/d/18NW2DJUvhh_VpKb9tn9nFxH-w8URxMoy/view?usp=sharing
If you are looking for a relatively cheap dual boost/OD then the Moller is worth checking out.
Old, overweight and badly maintained. Unlike my amps which are just old and overweight.
  • PaulMHPaulMH Frets: 17
    I’d also suggest the Trex Dr Swamp for consideration, great 2 channel overdrive and similarly cheap as a used buy
