As good a place to start as any
http://www.coda-music.com/boss-harmonist-pedal-p-13341.html
the Boss unit.
So anything a little simpler on the market for the simple?
(formerly miserneil)
But the key to then we're placement in the chain
The Digitech Harmonyman is good - you can save four presets and it can be set up to sense the key you're playing in and generate an appropriate 2-part harmony.
It also has a loop for your drive pedal(s) so that the input sees a clean signal but the effect is applied after the drive.
It's really easy to use - I've probably managed to make it sound more complicated than it actually is!
My music:- https://soundcloud.com/hubobulous
I think (And no doubt someone else will think differently) that pitch shifting is altering the original note, and harmonisation is adding an extra note to the original note. (If that makes sense)
