I've been waiting for news on this one and my old one doesn't leave my board. Dark horse is a good description of these pedals and Gassage once mentioned that the guitarist in a UK Pink Floyd tribute was using 2 of these for his sounds.
https://zoomcorp.com/en/us/multi-effects/multistomp-pedals/ms-70cdr-plus/
I had the original one and while it was great I just couldn't cope with the fiddly UI. I ended up giving it to my daughter and buying a Line6 M5 instead. The UI on the M5 is massively better and I think it sounds a little better too. I do sometimes miss the ability to stack multiple effects though.
i've only recently removed my 100BT from my board after it being there for years and years and i gotta say it's refreshing it's not there as i relied on it so much with its massive reverbs etc
It's a modified version of the Bass Para EQ which can dial out the relevant frequency. All credit to Victor Tabas, it's a great addition. And the software in general makes it a doddle to add effects from the different models, top stuff!
It's still a very capable unit with better navigation than the original, and if you're owning one for the first time, you may not notice anything 'thinner' or brittle about the sounds, but I didn't like it and returned it and I'm glad I've stuck with my trusted original version. On that note, if anyone has an original one to sell, I'd be interested.
MS-50G and thought there was 'tone suck'. It just goes to show what our ears and brain tell us and I'm glad it's worked out well for you
Anyone got one of the new ones or had both? EDIT: Sorted and got one
I had the 50G at the same time as the CDR+, i had the 50G loaded with the CDR algorithms so other than not having stereo in, it was a like for like comparison.
I'm with John. The + sounded very similar but with no tone suck (I used to bypass mine when off), less noise and a higher fidelity.
No complaints, it's better in every way apart from the build materials. Lots more plastic on the new ones.
