Dual Tier Keyboard Stand £40
TTonyTTony Frets: 27971
Pretty standard keyboard stand, but with the extension arms so you can add a second device (I usually have a laptop on the higher tier).  Obviously disassembles and folds flat for storage and shipping!
The height/width is adjustable using the toothed clamp in the middle, so nice and secure / stable.  The extension arms can be adjusted for angle, and the stabiliser bar at the back is width adjustable.
Keyboard shown so you get an idea of the size - easily takes my Oxygen 49.  I put a wooden shelf across the extension arms for the laptop to sit on.
£40 plus delivery (should be £10 via ParcelForce).  Unless you're in the area of IP22 in which case, you're welcome to collect.
