Hello!
I'm after a little advice as to what tools to use in making up some guitar cables.
For various reasons, I'd long since lost almost all of my tools - but on the plus side I'm now in a position where I can buy some new ones!
So, what I used to do when wiring up jack leads was simply hold the jack in a vice (with a bit of cloth or something to stop it marking the jack itself). As I don't have a workshop or vice anymore, I was thinking of what other options might be useful. So far I've thought of nothing (other than a vice).
Any suggestions?
I'm also going to be using just plain old snips for cutting and stripping cable - anything else I should consider? Was also thinking of getting something that will "crimp" the end of the jack neatly (I used to use
these, but they were never great).
Thanks!
Don't mess about with bits of old underpants in the vice! A few layers of gaffer tape or similar will do, or a set of plastic jaws.
For more than 50yrs I stripped cable with side cutters (and still do at home now). You want a pair of overall length ~120mm and a cutting edge about 12mm. But if you are contemplating a LOT* of cables I strongly urge you to buy an automatic cable stripper and pay for a good one from RS or similar.
Small snipe nosed pliers, again about 120mm and a pair of big lekkies pliers to nip up the back end of Neutrik jack plugs.
If you want to do a really "pro" job, a variety of sizes of heat shrink sleeving and some silicone sleeving. and therefore, heat gun.
Tube of silicone grease or you can use silicone (bumper) spray. Just squirt some in the cap and dip in.
Test meter but I find a simple continuity buzzer is much faster.
*If you are not doing a lot, don't do any and give Rob (Kabl) the living!
Dave.
The wood idea would (ha! oh dear ...) be good, except I no longer own power tools. Annoyingly I could do with a drill, but only to make the holes to mount the PSU on my pedaltrain.
I've a bunch I want fo make up, half because it would be way way cheaper, and the other half because I've not done anything practical in fookin' ages.
Probably twenty patch leads and a few straight leads.
"Continuity testing is useless for cables as it won't pick up faults that will render a cable half working but not 100% "
Not sure what you mean Danny? Can you give a "half working" example?
I must have made up 1000s of cables in my time and used many and various testing systems including one that employed a computer and a custom program. (I built the test beds, some other cleverer sod wrote the progg!) But although the system impressed visitors to the factory it was still only essentially a battery and a bell! (just did up to 96 ways in one hit)
Dave.
"passing balanced ac signal current audio they can exhibit faults which often manifest in loss of low end, prone to feedback etc."
^ Total Russ Andrews bllx. Just one F.A.C.T. The source and sink impedances in a balanced system are unlikely to be matched to better than 1%. No cable fault other than OC or S/C could be within an order of that.
Dave.
