The App only pairs to Katana Go MIDI, which only controls the Go settings.
To get audio, you need to pair to Katana Go Audio, just like you would to pair to something like a pair of headphones, via your phones bluetooth menu.
I've just used Spotify to play through the GO, while changing settings with the app.
The key is that the phone simply outputs audio to the Go's Bluetooth Audio connection, while the app is using the Go's MIDI Bluetooth connection.
It's no different to how I can play Spotify/Use my van's bluetooth connection, while at the same time my smart watch communicates with my phone.
I think you have to do it in a certain order? Like connect to Katana Midi first, then katana audio second, but the app should prompt you.
Go Audio, acts like any generic Bluetooth Audio device.
If you go into your phone's Bluetooth settings, search for new/unpaired devices, and provided the Go is turned on and the Bluetooth active, there should be another listing for Katana Go Audio.
I guess there's a security reason why it can't be done with a single button to connect both app for control and BT audio?
