This one looks simpler and quicker to build if you don’t use the gloop on the JHS.
But it’s orange and the control knobs are far too small IMO.
Also not sure about the foam under the Valve melting with heavy use ?
Also wondering how this sounds compared to a Behringer vintage tube monster VT999 & a VT911 vintage tube overdrive which both have valves for around £60 each new.
I wonder if the valve operates at proper high voltage?
Maybe everything socketed so you can fit all the components/wires? Maybe even throw in a few different values to experiment with.
https://youtu.be/NsFy3HV8lAI
I would love to try one but the very small adjustment knobs put off .
