Amp stand
Delaware_123Delaware_123 Frets: 92
in Amps
Can anyone recommend an amp stand? I’m using a mesaboogie studio 22 at home and I’m loving it but sounds even sweeter when elevated a couple of feet up. Any recommendations would be hugely appreciated
  • personalnadirpersonalnadir Frets: 358
    edited May 13
    I've used have a amp stand from LakefrontWoodCo. Stuff from Poland takes an age to reach the UK, but am happy with the stuff they've made for me. They were happy to adjust their dimensions, so could be worth seeing if anything there is in the right ballpark https://www.etsy.com/uk/shop/LakefrontWoodCo
  • thomasw88thomasw88 Frets: 2343
    my favourite one is this althought this is for stage so may not work at home unless you're a couple of feet away.
    https://www.thomann.de/gb/ultimate_amp150.htm?glp=1&gad_source=1
    it doesn't get in the way of effects send/returns and other cables in the back of the amp.   It gives a decent angle, and folds down really well.
    alternatively a painters step actually does a really good job/ stick a rug over it or something and it will last forever..
  • DannyPDannyP Frets: 1696
    I have the Fender one, but I wouldn't buy it again - purely because the bit the amp sits on is welded in a right angle. It's durable, but it means it won't fold flat, making it a PITA to store and transport.
    So that issue is worth bearing in mind, I guess.
  • mudslide73mudslide73 Frets: 3109
    I've recently started using an upturned document crate like this https://cratemate.co.uk/crates/standard-lidded-crate . I previously used an Auralex Gramma mat so place that on top of the crate. It doubles up as a great storage and transportation unit for gigs.
  • sw67sw67 Frets: 236
    I have the boss stand - works well
  • KeefyKeefy Frets: 2363
    I’ve had two purpose-made amp stands that failed in use. I now use a decorator’s ‘hop-up’ that I got from Wickes for less than £30, and painted black - it’s both lighter and stronger.
  • rze99rze99 Frets: 2387
    I use a folding piano stool for smaller combos which is adjustable.
  • jca74jca74 Frets: 376
    The other advantage of a hop-up is that it is level, while most amp stands are tilted backwards - this is fine with a combo, but less so with a cab and head setup.
  • fretfinderfretfinder Frets: 5107
    edited May 14
    I had these two made from some left over oak worktop I had and I’m very happy with the results. The amps are at a better height for home playing, my two pedalboards fit neatly underneath, and the stands look great imho!
    260+ positive trading feedbacks: http://www.thefretboard.co.uk/discussion/57830/
    0reaction image LOL 5reaction image Wow! 1reaction image Wisdom
  • gubblegubble Frets: 1768
    ^ Great solution in terms of practicality and aesthetics
    You should think about making these commercially
    Thanks. Me being a walking disaster at DIY I had to pay someone to make them for me! Out of interest what sort of retail price do you think they might sell for? They cost me considerably less than the ones in Etsy from Poland that were linked in an earlier comment, although I did provide the wood for mine.
  • Alex2678Alex2678 Frets: 1168
    I use a PC monitor stand/riser to lift my amp up a bit, gotta make sure it can take the weight though
  • Delaware_123Delaware_123 Frets: 92
    Thanks for the suggestions guys. I think I’m going to try a painters step or even an old milk crate maybe
