Home | Mixing Station
Ebay mark7777_1
Ebay mark7777_1
An iPad gives slightly better access and larger screen, but my standard is an old laptop connected via a LAN cable. Since I’m playing and mostly have my hands full I’m not fiddling all the time and the screen will black out in many a set, but I have instant access if need be. We essentially set up in a small theatre and I put all the kit mics etc. on their respective channels with the appropriate processing, gates, comp, reverb etc.
At a gig I load the basic setup and tweak to accommodate for badly places mics or different gain settings on the instruments. Eq the system for the room and off we go.
When I mix others I use the laptop and ride it all night if required.
Watch yootoob vids to see how it works and watch out adding fx in monitor sends, it’s not always obvious!
