I just bought one of these and I'm really impressed with how it sounds for the money.
I have the 40w and I'm not sure if it would keep up with a drummer (it would be very dependent on the drummer), but I did try the 150w at the shop and I didn't need the extra power for home use, but I'm sure you could use that at a rehearsal.
It's the very modern Mark Bass sound that I like if you want more retro sounding then it's a Fender Rumble I think.
Eqd Speaker Cranker clone
Someone brought an EBS Session to mine round the other day and the TE was so much better.
Older Trace Elliots would be a close second - with a slightly more modern, cleaner sound - but aren’t quite as solidly made and reliable, although a similar weight and price.
Like I said, castors added.
ŠKODA Yeti.
Guitar Bomb Giveaway – Win a Warm Audio Centavo Overdrive Pedal
That and I've just purchased my second drum kit this week, so need to tune those two up.
I need something to keep up with a drum kit and a loud valve guitar amp while rehearsing at mine.
In my experience you want around 300W (solid state) plus to keep up with a drummer and valve amp.
I think a Peavy T-Max or Trace second hand will be a good option as previous comments have pointed out the weight puts most people off which means they can be had for pennies.
A lot of the new Class D stuff is very good and very light, Ashdown often has a mixed rep for reliability, however I have been happy with the 3 Ashdown Units I have had. The OriginAL head is 300W (and can be bought already mounted in a speaker as a combo) and will not break the bank even new.
As power supply components have got smaller, lighter and more efficient it seems this translates into less punch and perceived volume for a given rated output. When you get to the Ashdown era or later I would agree that 300W is better.
Speaker type and sensitivity still matters as it does with guitar amps - a big solid 1x15” or 4x10” will be fine, a 2x10” generally won’t, even with more power - unless it’s something like an SWR Goliath Jr, those are really loud. (But also weigh about the same as most 4x10”s.)
Hartke HA3500 heads are pretty good and often go very cheap. The newer LH500 does as well but it's a bit soulless and crap. Damn loud though, and actually fine if you've got some sort of preamp pedal. One with a £40 clone of a BDDI would be fine.
The really early Ashdown UK made MAG series are pretty good. The Red Panel MAG400H is a cracker and usually very cheap now. I gigged one of those for years.
Alternative option that works well is a powered PA speaker and a preamp pedal. A used Yamaha DXR10 and the aforementioned £40 BDDI clone would be plenty, with the added benefit of being able to put vocals through it too if you have a little mixer.
Ashdown 1x15 cab at £95: Ashdown ABM 115 Evo 2 compact cabinet **Further Price Drop £95* - Amps and Cabs For Sale - Basschat
Orange OB1 300 Combo for only £350: Orange OB1-300C 300w Combo - £350 - Amps and Cabs For Sale - Basschat
Big old heavy Tech Amp head and 4x10 cab: Tech 21 Landmark 300 & B410 cabinet PRICE DROP £450!!! ONO - Amps and Cabs For Sale - Basschat
Ashdown ABM500 head at £175: Ashdown ABM 500 watt EVO 111 bass head. £175. - Amps and Cabs For Sale - Basschat
Of that lot, I'd probably have the Orange combo. The OBC amps sound excellent. It's a bit heavy, but if you don't have to move it....
Quite a few small amp heads on here too at various prices.
