Glue for Guitar Nut
SchnozzSchnozz Frets: 2147
I'm staring at a bottle of Evo-Stick wood glue and a bottle of Gorilla glue (I won't use the latter due to the expanding part).
The nut is graphtec on maple - What does everybody use?
I remember mixing some stuff in my garage for a bass that had a metal nut, which wouldn't work here.
  • WezVWezV Frets: 17461
    2 small drops of superglue
  • guitars4youguitars4you Frets: 15378
    couldn't agree more - And you can use the strings, tuned back to pitch to, as a clamp, but ensure it sits correctly with regards to no over hang on on side, or the other, of the fingerboard
  • OilCityPickupsOilCityPickups Frets: 11855
    I use the Loctite Power Gel ... it has a high acrylic content and a slight elasticity that stops a random knock loosening yer nuts
  • bluecatbluecat Frets: 644
    Gorilla glue clear will not expand. But I would go the same way as WezV,that will be good.
  • SchnozzSchnozz Frets: 2147
    Thank you guys - I had some clear Gorilla super glue as well, so I've used that and it has done the trick. Much appreciated.
  • AdeyAdey Frets: 2777
    edited June 12
    I've never had a problem with good old PVA. Only needs a smidge.
