Arguably one of Martin’s greatest designs. In very good overall condition with very minor marks (most notable one a surface hairline scratch on back, it looks worse in the photo than in real life) .
Saddle height left (approx 3mm at bass end and 2mm at treble end) and set at low action (2.1 bass side, 12th fret and 1.5 treble side). No modifications, holes drilled or repairs.
£3250 - based in Swansea, happy to post or meet. Now £2950 £2750 £2500
The current model sells for £4735 and has a 1-3/4" nut width (this one is the 1-11/16" iteration). This early 2000s model has a very fine selection of timbers.
Full specs below from Martin according to the serial number
Model J-40
Construction Dovetail Neck Joint
Body Size J-14 Fret
Top Material Sitka Spruce
Top Detail None
Rosette Abalone with Multi-Stripe
Bracing Pattern Forward Shifted X Brace
Brace Shape Scalloped
Brace Material Sitka Spruce
Brace Size 5/16"
Back Material East Indian Rosewood
Back Detail None
Back Purfling/Strip Style 45
Side Material East Indian Rosewood
Side Detail None
Endpiece White
Endpiece Inlay Multi-Stripe
Binding White
Top Inlay Material Multi-Stripe
Side Inlay Material Multi-Stripe
Back Inlay Material Multi-Stripe
Neck Material Genuine Mahogany
Neck Shape Low Profile
Neck Taper Standard Taper
Plek Yes
Nut Material Bone
Headstock Shape Solid with Square Taper and
Diamond
Headplate Material East Indian Rosewood
Headplate Detail
Headplate Logo Style Block Inlay
Headplate Binding
Material White with Multi-Stripe
Heelcap White with Multi-Stripe
Fingerboard Material Ebony
Scale Length 25.4"
Neck Joins Body At 14th Fret
Number of Frets Total 20
Fingerboard Width at
Nut 1 11/16"
12th Fret 2 1/8"
Fingerboard Inlay
Material Abalone
Fingerboard Inlay Style Reduced Hexagon
Fingerboard Binding
Side Dots Black
Back and Side Finish Gloss
Back and Sides Color None
Finish Top Gloss
Top Color Clear
Finish Neck Satin
Neck Color Dark Mahogany
Bridge Material Ebony
Bridge Style Modern Belly - Drop in Saddle
Bridge String Spacing 2 1/8"
Saddle Compensated Bone
Saddle Radius 16"
Tuning Machines Gold Enclosed Gear
Recommended Strings SP Acoustic 92/8 Phosphor Bronze
Medium (MSP4200)
Knob Large
Bridge Pin Material White Plastic
Bridge Pin Dots Abalone
Pickguard Faux Tortoise
Pickguard Inlay None
Case Ply Hardshell
Label None
Electronics Optional
Left Handed Availability Yes
Country of Origin USA
