It really impressed me. I went in to see the od1x and ds1x but time was not on my side and the dude in the shop was most keen on the adaptive distortion for versatility.
Fao
@monquixote possibly?
Anyway, it went from a transparent clean (no drive at all) boost pedal through to quite high gain 80s esque levels of drive.
And it sounded really, really great at all settings!
For reference I went through the Bright channel of a fender 2x10 vibrolux. Which was a great sounding amp - and sounded great at true bedroom practice levels, too! (I was given a very friendly, and thorough, demo
![:) :)](/plugins/EmojiExtender/emoji/fb/1.gif)
). Minor hair trigger on the volume between bedroom and loud home practice, but there have been much worse!
So, at 0 it can be totally transparent - dialled to sound identical to the amp, with either volume match, cut or boost (tons on tap). Then you can boost or cut the treble and bass content.
The neatest thing was the low strings remained defined and the high strings were never shrill.
Then we worked the gain range. It was very touch sensitive (we didn't touch the volume knobs but until max gain, pick attack could clean up quite nicely and gave excellent dynamics.
Why the Bright channel? I like spanky clean funk tones and spanky clean metal arpeggio tones. It would allow me to test the shrillness - and it didn't disappoint at all.
Even with the gain maxed, where randy rhoads tones were to be found, with the treble down to 1/4 or less (or even 0!) it remained defined when chugging on a bridge humbucker but smooth as you went up.
Only the most complex jazz chords sounded nasty - and to be honest, they didn't sound much better with no gain at all. Chromatic bass note chord runs were always driven or distorted, but never mushy or shrill - it looks perfect!
Until...
The noise floor.
This was my only gripe - perhaps a dodgy pedal, or perhaps because it's an old model.
I told the chap I'd come back on my birthday and try all 4, dyna drive, adaptive distortion, od1x and ds1x to see which would suit me the best. The adaptive distortion seems to be so perfect, but even on a humbucker, there is a definite level of hum and noise introduced when the gain is at half or above.
Anyway, I'd urge people to give it a go. It was great for overdriven 3 note funk work high up, or down low, as well as general chugging, fusiony lead tones (the shop guy was a great player!) and touch sensitive blues and jazz, or a transparent and totally noise free clean boost.
It was demod with a coily cable, which might not help.
I'll compare to the others, though. The ds-1x doesn't sound like it does od tones at all, so this one would be perfect if only for the noise floor.
