My band, Red For Dissent
This one is much more advanced. Hit 'new guitar' and off you go.
You can even press 'new guitar' again and compare across different setups.
https://www.instagram.com/insta.guitarstuff/
Can you make it compensate for Floyd trem?
On a related point: Slightly worried we could get into a rabbit hole, but my initial thought is that a given gauge of string (at rest) will always have the same tension. The trem spring stiffness will have some 'give' when you bend a string, but not sure if that varies by type of trem.
Best tune that third string to F
Crap, how many times have I rushed this lol!
Tension = unit weight * (2 * Length* Frequency)^2 / 386.4
Tension in lbs, unit weight in pounds per inch, length in inches, frequency in Hz
https://www.daddario.com/globalassets/pdfs/accessories/tension_chart_13934.pdf
