excel users?? HELP!
57Deluxe57Deluxe Frets: 7401
So I have a simple column of figures - in this case column L -  and have a TOTAL VALUE  cell (L14) containing the formula =SUM(L3:L13) which gives the correct result, but when I click away anywhere on the sheet it keeps automatically doubling its value!
I then have to reset the value each time and is sooo annoying. Google and Youtube talk about double entries but nothing addressing this specific issue.
Thanks if you know.
Excel Office 2003 edition.
<Vintage BOSS Upgrades>
  • darthed1981darthed1981 Frets: 13697
    Try copying and pasting just your column of figures into a new worksheet, using paste special >> values
    Then use autosum at the bottom.
    Then try clicking around your new, clean sheet - all OK?
    I'd guess some macro code or something elsewhere on your original sheet that's messing with it.
  • ShrewsShrews Frets: 3237
    Click that box above 1 and left of A to highlight the entire sheet and reset it all to numbers. Then put the formula in again and see if it's doing the same thing.
  • 57Deluxe57Deluxe Frets: 7401
    Cheers to both suggestions!
