Pinnacle of guitar valve amps the Matchless SC 30. It has been an extremely difficult decision to list my Matchless SC 30 but it doesn’t get used much at all now and only been used at home. If you are viewing this ad you probably know about the heritage of Matchless and the DC/SC range. The tone of this 2 channel amp is just breathtaking with any guitar configuration. Channel 1 gives a fantastic clean and typical grit when pushed. Channel 2 has the best overdrive sound I’ve ever heard in 40 years of playing valve amps both professionally studio use and at home. It’s in excellent condition and comes with the channel foot switch. Also have a professional cover included. The waiting list for this amp from Matchless is about 12-18 months and new are around £4500.
This collection only. Happy to send more photos on request. Thank you for viewing this amazing amp.
Matchless SC Description
This is what changed the amp world. The DC-30 was the company’s first design and still leads the lineup.
Thirty very conservatively rated watts from a quartet of EL-84’s, through two channels, each with unique voicing and tone control layouts, produce a world of tone choices. True “Class A” configuration gives rich, complex harmonics whether played clean, mildly overdriven, or with all out power tube saturation. This means you should sound great in any situation, in any music style.
A long list of musician designed features includes: highly interactive tone controls and circuitries unique to each channel, bypassable master volume, individual channel effects loops, cut control for high frequency shaping, high and low (30 or 15 watt) power settings, selectable output impedance and phase inverter switches allow the use of additional speaker cabinets or amps in-phase with the DC-30.
The preamp sections are based on a layout of two 12AX7’s in Channel 1 and one EF86 in Channel 2. The two 12AX7’s in Channel 1 create a parallel-triode circuit with interactive bass and treble. The one EF86 in Channel 2 consists of a high-gain pentode coupled to a six-position tone switch. Outright benefits include quick dial-in of new tones and an easy return to the settings you prefer. Also “high treble” cut control, master volume, with a bypass feature that offers flexible control of the power amp section. The power amp is fed by a 12AX7 phase inverter, which drives four EL84 power tubes. The rectifier circuit gives you the flexibility of using one 5AR4 for a quick attack or you can use two 5V4’s for a smooth, round response. Other professional features include an effects loop, half power-mode switch (a conservative 30 watts switching to 15 watts), output impedance selector (4, 8, 16 ohms) and a speaker phase-reverse switch.
