How do people go about arrangement and structure when writing their stuff?
I've pretty much always gone with the flow and gone with what feels right - with varying degrees of success. However, I've also thought that a more studious approach might pay dividends and help me get more things finished - which of course is a big issue.
I write quite a lot of instrumental stuff, so thinking in verse, bridge, chorus, intro, outro, middle eight terms doesn't always work - although often times it does - it's just that there's something else in place of the vocal carrying the song.
Anyway, what I'm trying to do is come up with a way of mapping out an arrangement - firstly to analyse and learn from songs/ pieces of music I like, then use as a means of sketching out my own tunes, so that I'm actually planning for things like changes in dynamics, instrumentation, etc - for example, plan from the outset for the drums to drop out during an interlude etc.
I'll share an image of the song map I did yesterday evening to illustrate the idea when I have access to imgur. It's a lot of work, but potentially useful, especially if used to avoid falling in to the trap of doing the same thing every time.
If you use Shuffle mode you can also literally move any part of the arrangement and the sequence will snap back into place with no gaps. Very useful for adding a double 2nd chorus for example or adding an extra bridge section.
The actual arrangement for me depends on the song. Some songs have no bridge or chorus at all ... Take Folsom Prison Blues, it's just verses and 2 little guitar solos.
Other songs just loop the same 4 chords and rely on building up and stripping down to maintain interest ... With or Without you by
I generally write the song on acoustic and use my phones voice memo to record it, then keep changing and adding sections until it's interesting enough on just an acoustic. Then once I move onto a DAW I try and approach it like a band would, in as much as I work on the bassline, then the keys etc ... one instrument at a time
