I acquired a Squier Bronco Bass, which was found abandoned by a canal a few years ago and given to me.
I've set it up, and it plays so much better than it ought to. Plus, as it is a short scale, my guitarist's brain loves playing it, and it has fast become my 'couch bass'.
My question is that I would like to look for a slightly meatier pickup to replace the stock 'Strat' one, and so I wondered if anyone here may know of anything that would suit my needs.
Ideally, I would like some meat, with clarity, and I mainly play post-punk and rock stuff these days.
I love this cheap bass's simplicity, short scale, and neck. It feels ace, so it might be worth investing a few quid in a decent pickup with more balance across the four strings in output.
https://www.homeoftone.co.uk/blogs/news/new-squier-bronco-bass-upgrade-kit
Guitar Bomb Giveaway – Win a Warm Audio Centavo Overdrive Pedal
https://www.ebay.co.uk/itm/144140836493?var=443444555758
Bandcamp
Currently, it owes me absolutely nothing (though I have just ordered the super cheap rail pickup to try out)
I'm too cheap to spend money on a hand wound UK specific Bronco pickup unless someone else has tried one and has told me it is worth its weight in gold (or printer ink)
Bandcamp
If you find the rails pickup too middy and muddy, try wiring it in parallel not series - that sounds very good for bass usually, clearer and more dynamic than series. To do that, disconnect the red and white wires, and connect one to the green wire (probably the white) and one to the black (probably red) - if you get silence, it’s the other way round .
Hum is harder to EQ out of a bass sound than a guitar, because 50/60Hz are fully within the note range of the instrument. ‘Modern’ noise from switch-mode power supplies, lighting etc is no less of a problem for bassists either.
I will whack it through my bass amp at volume later and see how it holds up at gig volumes.
Thanks to everyone who helped me out; all your knowledge was beneficial.
