It's also a bit odd to have the fretboard attached directly to the body on this style and heritage., but it does mean it is a bit easier to do a neck reset as you can get straight to the dovetail with the fretboard off... and taking the fretboard off would also give chance to add a reinforcing bar to the neck.
Instagram
I did get a torch inside and managed to take a picture of the inside of the neck joint last night and that small metal plate with two screws, and the tip of a threaded rod or bolt, is exactly what I saw. So I suspected that it was bolted on. I'll definitely pick away at it and see if I can remove the neck easily.
