I realise this is a very specialist issue.
Got my RC-2 looper alone in the DSL40C’s effects loop. It’s infuriatingly loud regardless of master volume levels, which may or may not be related.
The looper has this ‘auto’ mode that starts playing a rhythm and recording a phrase when I press the footswitch. It used to work fine when I had the looper going into the front of the amp, but now it just blinks as it is not detecting an input signal. It does record fine on ‘manual’ mode, but I can’t seem to manage pressing the footswitch and playing without mistakes. I wanted to use a bit of preamp drive so I need the looper after the preamp — ie in the loop.
Any idea what could be wrong with the setup? Perhaps I should try adding a buffered pedal in front of it?
Cheers,
Jon
Try turning the channel volumes up and the master volume down.
Another bit that's also consistent with the effects loop having too low a volume: the recorded phrases had a hum and noise that wasn't obvious in bypass mode.
I will try putting another pedal in front of the looper when I get back (I'm in Oxford atm). I've read on the HoF's manual that it's happy in the effects loop whatever the volume.
Jon
My trading feedback: https://www.thefretboard.co.uk/discussion/210335/yorkie
Mine does have external volume knobs. The problem is that it's practically too loud on 1. I love this looper, it was my first ever TFB purchase and it has been on my board since then. Just not in the effects loop!
Turn the channel volumes up and the master volume(s) down.
In that case you need something like a volume pedal, or an ‘anti-boost’ (passive volume control in a box - I think @Danny1969 makes them) to put after the RC-2. That will let you turn up the amp's volume controls, then the final level down (including the RC-2 rhythm sounds) with the volume box.
Are there any other loopers with built-in rhythm boxes which might be happy in Marshall's quiet FX loop? My TC stuff has on occasion gone in the loop with no problems, but I'm not sure how their Ditto thingy compares against the RC-2. I'd be keeping the RC-2 anyway – it's a killer practice tool and I can still use it downstairs with the AC15.
Here is small but relevant extract of the DSL40C schematic, captured from an image search engine. From left to right, we've got EQ section, then in and out to the (digital) Reverb, then Volume – so it's NOT really a master volume – and then FX in and out, which then goes into PREAMP_OUTPUT.
So, this schematic explains why:
- input signal to the looper is very low at recording levels (volume=1-2), which means loops and overdubs register some hiss.
- you can only control the volume of the built-in rhythm box using the looper's controls. VOLUME does not affect it, because the drums are separate from the input.
- playing doesn't trigger the start of a phrase at recording levels because the FX loop is quiet.
- turning gain down and volume up does cure the issue
- adding a passive volume box after the looper allows you to crank both gain and volume if you need to, and keeps the looper happy.
- if you added a tremolo box in the FX loop, you would be using the tremolo after the amp's reverb, Fender style.
I love both the DSL40C and the Boss RC-2, so I'm going to get my soldering iron out and build a little volume box :-)
Thanks for your help, everyone and particularly John who's always spot on.
Jon
- The effects loop volume issue we have diagnosed here.
- Except for the tuner, I don’t normally use pedals; my pedalboard doesn’t have any leds on when the pedals are off, so I frequently forget to turn the whole thing off.
Jon
